okramer
6 years agoExpected "channels" specification in the BSP's board_spec.xml but see nothing.
I'm learning about Intel's "channels" OpenCL extension for host-to-kernel and io-to-kernel communication. The training video says the specification of the board's available channels are in board_spec...
- 6 years ago
Yes host-to-dev channel and dev-to-host are supported only by "a10gx_hostpipe"BSP.
For question "Does Intel perhaps provide a BSP with ethernet available, since the dev kit comes with ethernet?", i would need some time to check it internally.
The BSP support host-dec streaming via pipe. The channel is provided for pipe to work. There is no difference between pipe and channel, it only the name difference here.
MEIYAN_L_Intel
6 years agoHi,
According to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/ug-aocl-a10pciedk-platform.pdf in Chapter 1.2.1, you have to choose the reference platform board variants by including board=<board name> as your aoc command option.
