Expected "channels" specification in the BSP's board_spec.xml but see nothing.
- 6 years ago
Yes host-to-dev channel and dev-to-host are supported only by "a10gx_hostpipe"BSP.
For question "Does Intel perhaps provide a BSP with ethernet available, since the dev kit comes with ethernet?", i would need some time to check it internally.
The BSP support host-dec streaming via pipe. The channel is provided for pipe to work. There is no difference between pipe and channel, it only the name difference here.
I don't think aocl is seeing a10gx_hostpipe. When I do "aocl install", am I supposed to provide it the path to hostpipe BSP? My directory structure is:
~/intelFPGA_pro/19.3/hld/board/a10_ref
board_env.xml
bringup/
hardware/
a10gx/
board_spec.xml, ...
a10gx_hostpipe/
board_spec.xml, ...
linux64/
scripts/
source/I ran aocl install $INTELFPGAOCLSDKROOT/board/a10_ref successfully, but when I do aocl diagnose acl0 I see:
BSP Diagnostics
Using Device with name: a10gx : Arria 10 Reference Platform (acla10_ref0)
...The diagnostic passes, but the device name = "a10gx" worries me. In $INTELFPGAOCLSDK/board/a10_ref/hardware/a10gx_hostpipe/board_spec.xml, the device name is given as name="a10gx_hostpipe", while in a10gx/board_spec.xml, it is given as name="a10gx". Does this mean I'm accessing the wrong BSP? How do I install the a10gx_hostpipe BSP?
