Expected "channels" specification in the BSP's board_spec.xml but see nothing.
- 6 years ago
Yes host-to-dev channel and dev-to-host are supported only by "a10gx_hostpipe"BSP.
For question "Does Intel perhaps provide a BSP with ethernet available, since the dev kit comes with ethernet?", i would need some time to check it internally.
The BSP support host-dec streaming via pipe. The channel is provided for pipe to work. There is no difference between pipe and channel, it only the name difference here.
Thanks Mylee.
If I understand correctly, host-to-dev and dev-to-host channels are currently supported only by the "a10gx_hostpipe" BSP. When I invoke aoc, I need to use "-board=a10gx_hostpipe", correct? The "a10_ref" BSP does not support host<->dev channels?
What about ethernet? From the user guide you linked to above, it sounds like I'll need to define a new BSP based on "a10gx_hostpipe" that adds the ethernet capability as well. Does Intel perhaps provide a BSP with ethernet available, since the dev kit comes with ethernet?
What about OpenCL pipes? I suppose the BSP somehow needs to support host<->dev streaming via pipes. Does Intel use channels under the hood for the OpenCL pipes implementation? So in order for pipes to work, the BSP must provide corresponding channels? I willl most likely use pipes, not channels, so this question is the most important.
