execute An814
Dear Support
I have the errors while generate HDL, I am using Quartus PRO 21. 3
I followed the AN814 instruction step by step all the way to Page 11, item 6.b.
Repeat step a. to generate HDL files for jesd204b_ed_qsys.qsys and
dl_count.qsys.
Error: jesd204b_subsystem: jesd204b_duplex0 has port reconfig_avmm_read declared with VHDL type standard logic vector which is declared as standard logic in file jesd204b_subsystem_jesd204b_duplex0.ip
Error: jesd204b_subsystem: jesd204b_duplex0 has port reconfig_clk declared with VHDL type standard logic vector which is declared as standard logic in file jesd204b_subsystem_jesd204b_duplex0.ip
Error: jesd204b_subsystem: jesd204b_duplex0 has port reconfig_avmm_waitrequest declared with VHDL type standard logic vector which is declared as standard logic in file jesd204b_subsystem_jesd204b_duplex0.ip
Error: jesd204b_subsystem: jesd204b_duplex0 has port reconfig_avmm_write declared with VHDL type standard logic vector which is declared as standard logic in file jesd204b_subsystem_jesd204b_duplex0.ip
Error: jesd204b_subsystem: jesd204b_duplex0 has port reconfig_reset declared with VHDL type standard logic vector which is declared as standard logic in file jesd204b_subsystem_jesd204b_duplex0.ip
Error: jesd204b_subsystem: jesd204b_duplex1 has port reconfig_avmm_read declared with VHDL type standard logic vector which is declared as standard logic in file jesd204b_subsystem_jesd204b_duplex1.ip
Error: jesd204b_subsystem: jesd204b_duplex1 has port reconfig_clk declared with VHDL type standard logic vector which is declared as standard logic in file jesd204b_subsystem_jesd204b_duplex1.ip
Error: jesd204b_subsystem: jesd204b_duplex1 has port reconfig_avmm_waitrequest declared with VHDL type standard logic vector which is declared as standard logic in file jesd204b_subsystem_jesd204b_duplex1.ip
Error: jesd204b_subsystem: jesd204b_duplex1 has port reconfig_avmm_write declared with VHDL type standard logic vector which is declared as standard logic in file jesd204b_subsystem_jesd204b_duplex1.ip
Error: jesd204b_subsystem: jesd204b_duplex1 has port reconfig_reset declared with VHDL type standard logic vector which is declared as standard logic in file jesd204b_subsystem_jesd204b_duplex1.ip
Error: The system cannot be generated when there are errors.
Hi dsun01,
Just want to confirm that are you using the manual stated below for guidance?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an814.pdf
If yes, you should use Quartus Prime Pro Edition version 17.0 instead of Quartus PRO 21. 3.
The reference design requires that particular version.
Hope it helps.
Sheng
- ShengN_altera
Hi dsun01,
Hope it helps.
Sheng
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.- dsun01
Contributor
Hi Sheng,
Thank you very much for the reply, you answered my question, I was a little surprised for the application note limited to 17.0.
Have a great holiday,
David
- ShengN_altera
Hi dsun01,
I'm glad that the solution provided could help you.
I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Have a great holiday too.
Sheng
