TBaki
5 years agoError while Custom Component Importing to Qsys
I just added custom VHDL component in qsys. The module is just AND gate logic. I'm using quartus 13.1 version I'm getting error as,. Error: No modules found when analyzing null.
Nurina
5 years agoHi,
I used Quartus Prime Version 17.1. I believe that if it's analyzed correctly here it should be the same in v13.1 as well.
I've attached the .qar file here.
Nurina
TBaki
5 years agoHi,
Version 15, 16 17 ..it will work. Try with version I mentioned. With version 16 it worked for me. 13.1 didn't work. so posted the query. Thanks
- Nurina5 years ago
Can you try remove 'is' after 'process(clk)' and see if there's a difference there?
Nurina
