RFett
6 years agoError on attempt to download sof and jic file to Cyclon 10GX dev. board using JTAG. How to proper setup to get jic file programmed to EPCQL1024?
Using the C10 CVP sample project I added the Serial Flash Loader IP to the design into the top_hw.v. I setup the jtag chain for the Cyclon 10 GX Dev. Kit, download the 10 design (sof) -> ok and down...
RFett
6 years agoHi John
Thank you for your prompt answer. I tried to download as proposed and I am afraid it did not work. See screenshot below. A very worring thing is the readme file in the factory_recovery folder, containing the following sentence: "Note: .jic file cannot be programmed via Quartus Prime Programmer at this moment, will be fixed later in v18.0 or later build." Is this working indeed now?
