RFett
6 years agoError on attempt to download sof and jic file to Cyclon 10GX dev. board using JTAG. How to proper setup to get jic file programmed to EPCQL1024?
Using the C10 CVP sample project I added the Serial Flash Loader IP to the design into the top_hw.v. I setup the jtag chain for the Cyclon 10 GX Dev. Kit, download the 10 design (sof) -> ok and down...
JohnT_Altera
6 years agoHi,
I think your own design does not have the SFL design which is needed to program the flash. When you attach the jic file to the Cyclone 10 GX, you shouldn't modify the file but use the factory default program to program into the FPGA so that the SFL is loaded.
