error message: can't fit into the design
- 7 years ago
I have not modified the design which you have shared in previous post attachments.
- You can add Qspi and PLL in Qsys system(onchip.qsys/onchip.qip) and remove the pll.qip file from project and onchip.qip set as top level entity and compile. Attached the file do pin assignment and other configuration as per you requriment
For RSU design example (QSPI &PLL) look into design stores or follow an741 or check below video links
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf
https://fpgacloud.intel.com/devstore/platform/?search=RSU&acds_version=any&family=max-10search for reference design.
https://www.youtube.com/watch?v=Qgwd8ftiTZc
https://www.youtube.com/watch?v=bAyqWWm1yLU
https://www.youtube.com/watch?v=r3wcgr3LmjA
Anand
Anand
- AKAYA7 years ago
thank you for the reply....
the project is compiling now without any error...
thanks for the help
