AKAYA
7 years agoerror message: can't fit into the design
Hello, i am trying to use QSPI controller along with ALTPLL. But during compilation it gives an error. Am using pll configuration with 2 clocks C0 and C1. the error message is: Error (176394): Ca...
- 7 years ago
I have not modified the design which you have shared in previous post attachments.
- You can add Qspi and PLL in Qsys system(onchip.qsys/onchip.qip) and remove the pll.qip file from project and onchip.qip set as top level entity and compile. Attached the file do pin assignment and other configuration as per you requriment
For RSU design example (QSPI &PLL) look into design stores or follow an741 or check below video links
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf
https://fpgacloud.intel.com/devstore/platform/?search=RSU&acds_version=any&family=max-10search for reference design.
https://www.youtube.com/watch?v=Qgwd8ftiTZc
https://www.youtube.com/watch?v=bAyqWWm1yLU
https://www.youtube.com/watch?v=r3wcgr3LmjA
Anand
AnandRaj_S_Intel
7 years agoAttachment
