error message: can't fit into the design
- 7 years ago
I have not modified the design which you have shared in previous post attachments.
- You can add Qspi and PLL in Qsys system(onchip.qsys/onchip.qip) and remove the pll.qip file from project and onchip.qip set as top level entity and compile. Attached the file do pin assignment and other configuration as per you requriment
For RSU design example (QSPI &PLL) look into design stores or follow an741 or check below video links
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf
https://fpgacloud.intel.com/devstore/platform/?search=RSU&acds_version=any&family=max-10search for reference design.
https://www.youtube.com/watch?v=Qgwd8ftiTZc
https://www.youtube.com/watch?v=bAyqWWm1yLU
https://www.youtube.com/watch?v=r3wcgr3LmjA
Anand
Can you share the project?
thanks for the reply....
I am attaching the project here...
the QSYS is in the folder RSU--> OnChip.qsys
- AKAYA7 years ago
am not able to attach the project here
- AnandRaj_S_Intel7 years ago
- You have to delete the db and incremental_db folders and regenerate qsys and mega-wizard pll system and recompile the design and check.
I got your project, i have just followed above steps which solves the issue and Attached project for your reference. i have used quartus 17.0 std.
If you are still facing problem use latest version of quartus tool.
Anand
- AKAYA7 years ago
but the qsys file des not contain any ALTPLL or QSPI Controller....
duplicate
