EPM1270M256C4N Alternate part
Hi there
Referring to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max2/max2_mii5v1.pdf
MAX II devices support vertical migration within the same package (for example, you can migrate between the EPM570, EPM1270, and EPM2210 devices in the 256-pin FineLine BGA package). Vertical migration means that you can migrate to devices whose dedicated pins and JTAG pins are the same and power pins are subsets or supersets for a given package across device densities.
You can always refer to pinout files below to check on the pins layout:
https://www.intel.com/content/www/us/en/programmable/support/literature/lit-dp.html
Eng Wei
- Monika5 years ago
Thanks for your reply.
However, I am seeing EPM1270M256C4N part into EOL category, so looking for its alternate part. Could you please suggest the equivalent alternate part number?
