EPCS128 device flashing with .jic file not working
Hi Niranjan,
This is not possible. As long as you are able to power on the board, you will be able to detect the devices with Quartus Programmer Tool. Can you try to change all the switches to default position and reprogram an appropriate bitstream into it?
YL
- NShin37 years ago
Hi SooYL,
Quartus programmer can detect DE1-SOC board only when MSEL = 00000 and 01010. It is not detecting the board when MSEL = 10010.
I think the .jic file I downloaded in EPCS earlier (MSEL = 10010 ) has wrong pin connections. That's why tool is not detecting the board through JTAG.
I ran test.bat file from CD_ROM folder in support package. Alos tried to erase/overwrite default DE1_SoC_Default.jic file through MSEL = 00000 and 01010.
But the process failed halfways.
“ Error (209025) : A device’s Silicon ID is different from its JTAG ID… “
Thank you for suggestion.
Niranjan
