E-tile automatic adaptation issues
- 5 years ago
HI,
If you want to learn how Etile PMA adaptation flow works, then pls checkout below user guide (page 210, 211)
Else you want to see how E-tile Hard IP control the adaptation flow, kindly refer to page 109 of below doc
Like wise, you can also checkout E-tile hard IP example design directly for the design implementation example
dlim
HI,
dlim
- alexforencich5 years ago
Ok, I was under the impression that this was supposed to be automatic - just check the box, and the soft IP takes care of the rest. You're telling me that I have to implement the flowchart in figure 117 in that first link myself? That's rather lame, but I suppose at least the settings are stored inside the core so I just need to tell it what to do.
