10 years agoDs-5 debug on Arria 10 Reflex Alaric board.
I appreciate that this my not be the right place for this post as its not technically an Altera product. I did try Reflex first but they just said they do not support Bare-Metal development & pointed me back at Altera. I have recently taken delivery of this board & I thought I'd start with a simple Bare-metal Hello World test. I took the same project that I had used on the Arria V SOC but built using the aria-10dk-oc-ram-hosted.ld linker script. I then updated the DS-5 debug config to use Arria 10 SOC/BareMetalDebug/Debug Cortex-A9 0. On trying to load the image over the USB-Blaster I got the following error: stopping running target altera - arria 10 soc on tcp:localhost on connectionconnected to running target altera - arria 10 soc on tcp:localhost
execution stopped in svc mode at s:0xc0021788
s:0xc0021788 bx lr
cd "c:\users\gnewman\documents\ds-5 workspace"
working directory "c:\users\gnewman\documents\ds-5 workspace"
s:0xc0021788 bx lr
loadfile "c:\users\gnewman\documents\ds-5 workspace\hello\debug\hello.axf"
target message: memory access caused precise abort.
debug precise abort registers : dfsr = 0x00000817, dfar = 0xffe0ac00
error(cmd16-tad11-nal18):
! failed to load "hello.axf"
! failed to write 8 bytes to address s:0xffe0ac00
! bus error on memory operation.
set debug-from main
start
warning(cmd399-cor168):
! failed to start the target
! no function named "main" could be found
warning(cmd407): trying the entry point instead
error(cmd426): cannot find symbol to start or entrypoint, the file or load commands may be used to set the entrypoint
wait
In fact Ds-5 cant read any addresses in the oc-ram space. On checking further the only memory I seem to be able to access is 0xC0000000 – 0xEF7EFFFF (HPS-to-FPGA). Could this be a BootRom issue? Any help would be gratefully received.
1 Reply
I encountered the same problem. Did you solve it? Can you tell me the method?
