16 years agoDownload the software image Problem
Hi, there When I download the software image .elf file on the board. It shows the following error: There are no Nios II CPUs with debug modules available which match the values specifie...
14 years agoI get same error , and I could not fix the problem....Which ptf file I should embedded before RUN command....
"Spoc Builder output ptf file" or "quartus project ptf" file what is the solution?:(
