16 years agoDownload the software image Problem
Hi, there When I download the software image .elf file on the board. It shows the following error: There are no Nios II CPUs with debug modules available which match the values specifie...
16 years agoI think I figure out what the problem is. It turns out my external power adapter may not provide enough current. Now this error has been solve. But now the system displays another error like following:
using cable "usb-blaster [usb-0]", device 1, instance 0x00pausing target processor: ok
reading system id at address 0x021208b8:
id value does not match: read 0x377e31a2; expected 0x32aea7ef
timestamp value does not match: image on board is older than expected
read timestamp 3:15:53 2009/10/22; expected 9:53:01 2010/03/10
the software you are downloading may not run on the system which is currently
configured into the device. please download the correct sof or recompile.
restarting target processor I am working on it, and try to figure it out ASAP.
