15 years agoDMA on a DE0
Hi all, Can someone verify for me that they have DMA to SDRAM working on a DE0 board ? I've been trying to get it to work for a couple of days, but no joy. Here's how it's set up in SOPC builde...
15 years agoWell, since this is such a simple design, I decided to try out Quartus2 v11, and see if that helped matters, especially since you say the DMA ought not hang...
Long story short: it works in v11. I can't see anything that I'm doing differently (apart from minor things - there's a clock-bridge component rather than directly exporting the pll's scram clock). In any event, the last two times I've tried it, the SDRAM passes its DMA test as well as its CPU test... http://www.0x0000ff.com/imgs/fpga/dma-success.png Note that I'm testing the same memory-area as before. This is working at 100MHz as well, not just at the 50MHz I was trying on Quartus 10.1 Oh well, should have tried the later version earlier :( Still, glad it's working now :) Simon
