15 years agoDMA on a DE0
Hi all, Can someone verify for me that they have DMA to SDRAM working on a DE0 board ? I've been trying to get it to work for a couple of days, but no joy. Here's how it's set up in SOPC builde...
15 years ago --- Quote Start --- Ah you are correct, this whole time I thought the small memtest used the DMA. I think if you took the memtest code, and removed the flash testing stuff and switched the software over to using small printfs you could probably get it to fit in an 8k on-chip memory. --- Quote End --- I may give that a go, but I'm pretty sure I'm not over-writing anything at the moment - I'm printing out the addresses I'm using and...
- the MemDMATest is the last thing to allocate any RAM (for the DMA buffers) and they're well below the area I'm testing.
- the stack ought to be nowhere near where I'm testing either. The Memory extends from 0x800000 to 0xFFFFFF, and I'm only testing from 0xA00000 to 0xB00000 at the moment.
