slmel
5 years agodisplayport™ 1.4 TX only example design for Cyclone10 GX
We are currently working on Display port IP in Cyclone 5 GT board and Cyclone 10 GX. We started working on Cyclone 5 GT board. In this we used bitec HSMC board. Loop back example design worked ...
- 5 years ago
I found out below AN doc that may provide answer to you.
It's still referring to A10 DisplayPort Tx only Example Design but C10 GX DisplayPort design should be quick close to it as well
- Pls go through the AN doc in detail to learn about DisplayPort Tx only example design
- Chapter 1.4.4 - tell you on some debug feature
- Chapter 1.5 - teach you how to convert DP Rx to Tx example design to become DP Tx only example design
Since you are using custom board then it's very hard to isolate whether the failure is on board issue or Quartus design issue
- If you have Cyclone 10 Gx dev kit + Bitec DisplayPort daughter card then it will be easier to isolate out board issue
dlim
Deshi_Intel
5 years agoHi SLM,
The other forum link that you shared to me is for other user custom design debug. You can ignore it.
For your case,
- You should not use Cyclone V design as Cyclone 10 GX and Cyclone V is having different design architecture
- Intel doesn't has Cyclone 10 GX Tx only example design. The closest reference that you can refer to is Arria 10 Tx only example design. Arria 10 Tx only design is available in the link that I shared with you earlier.
Before you test out Cyclone 10 Gx Tx only example design,
- Pls make sure the default Cyclone 10 Gx Rx to Tx re-transmit example design is working on your board first.
- After that, you can then modify "Cyclone 10 Gx Rx to Tx re-transmit example design" to become "Cyclone 10 GX Tx only example design" by referring to Arria 10 Tx only example design
dlim
