slmel's avatar
slmel
5 years ago
displayport™ 1.4 TX only example design for Cyclone10 GX
Hi, We are currently working on Display port IP in Cyclone 5 GT board and Cyclone 10 GX. We started working on Cyclone 5 GT board. In this we used bitec HSMC board. Loop back example design worked ...
  • Deshi_Intel's avatar
    5 years ago
    I found out below AN doc that may provide answer to you.
    It's still referring to A10 DisplayPort Tx only Example Design but C10 GX DisplayPort design should be quick close to it as well
    • Pls go through the AN doc in detail to learn about DisplayPort Tx only example design
    • Chapter 1.4.4 - tell you on some debug feature
    • Chapter 1.5 - teach you how to convert DP Rx to Tx example design to become DP Tx only example design
    Since you are using custom board then it's very hard to isolate whether the failure is on board issue or Quartus design issue
    • If you have Cyclone 10 Gx dev kit + Bitec DisplayPort daughter card then it will be easier to isolate out board issue
    dlim
