matif1
6 years agoDesign not found for Transceiver Design Flow Level 2 - The Avalon MM Master
Can you please share design of Transceiver Design Flow Level 2 - The Avalon MM Master? It is not available on your website
CheepinC_altera
6 years agoHi,
As I understand it, you encounter some error related to the KDB solution rd03172014_8. As I look into the KDB and also the CV device handbook, it seems like the CV device with -6 XCVR speed grade and -8 core speed grade does not support Byte SERDES when the PCS-PMA width =16/20.
You may try to disable the Byte SERDES to proceed. If need Byte SERDES + PCS-PMA width =16/20, you will need to look for other CV devices. Sorry for the inconvenience.
Chee Pin
