10 years agoDECA Kit Lab 8 MIPI Camera Working?
I am working with the Max 10 DECA Kit, and am working on Lab 8 from the Wiki. When I compile the completed project, start the code on the fpga, and use the System console to start the tcl script, I get an screen that is totally aquamarine green. I can see no influence from the camera. I've tried resizing the TPG image and turning off the TPG image with master_write_32 $nm $frm1 0, but there is absolutely no reaction on the monitor. Do you have any advice to how I can confirm the Image Sensor is working? Confirm the tcl commands are working? Any other advice? Thank you1 Reply
Are the LED's ON or OFF? I suspect the Nios II software may not be running. The software configures the MIPI sensor to the proper resolution. Upon completion, the LED's are 7:4 = Lit, and 3:0 are off
you can email [email protected] for additional DECA questions. Thanks, -Terry
