MeiB
6 years agoDebugging SW in DS-5 Eclipse Using DE-10 Standard board (ARM Cortex-A9 Core)
Hi, Folks,
I have an Ubuntu VM (16.04) set up to connect to DE-10 board through the JTAG interface and the mini-Uart. I was able to blast FPGA image into the board; run a lightweight Linux shell ...
Isaac_V_Intel
Contributor
6 years agoHello MeiB,
Can you confirm if you follow the build U-Boot process for Cyclone V?
Can you follow these steps at the link that I gave you? Until the step "9. Serial console will display that SPL ran fine and calibrated DDR successfully"
There's no problem with the versions.
Isaac Vazquez.
