11 years agoDE5-Net uses only 4 PCIe lanes
Hi everyone,
after installing a DE5-Net I ran the aocl diagnose acl0 command and I saw that the top transfer speed was of only 1124.51 mb/s and 1559.28 mb/s for writes and reads respectively. It looked odd since the beginning because with 8 lanes that transfer at 500MB/s/lane I have a nominal speed of 4000 MB/s and the results I got show only a 38% of efficiency in the driver. Thereafter, I wrote my own OpenCL benchmark increasing the block size and I got similar results. Still perplexed, I looked into the driver and I found the following statement: --- Quote Start --- The driver achieves approximately 3100 MB/sec on gen2 x 8 PCIe core with SG DMA on Stratix IV GX FPGA (77.5% efficiency) --- Quote End --- This showed me that I'm getting only half of the achievable bandwidth. Finally, using the PCI utilities I found out that even if the PCI slot is a x8 the card has negotiated a x4 width (see output below). Is it a driver problem? Am I missing something? Does somebody know how to use all the 8 lanes? p.s: I don't know if it's relevant or not, but I also made sure that PCI Express Control DIP Switch on the bottom is set as suggested in the user manual: SW7.1 and SW7.2 off, and SW7.3 on. # lspci -vv -s 0a:00.00a:00.0 Unassigned class : Altera Corporation Device ab00 (rev 01)
Subsystem: Altera Corporation Device 0004
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 16
Region 0: Memory at f2100000 (64-bit, prefetchable)
Capabilities: MSI: Enable- Count=1/4 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port# 1, Speed 5GT/s, Width x8, ASPM not supported, Exit Latency L0s <4us, L1 <1us
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=01
Status: NegoPending- InProgress-
Capabilities: Vendor Specific Information: ID=a000 Rev=0 Len=044 <?>
Kernel driver in use: aclpci2 Replies
Ok, I was missing something: BIOS settings :oops:
Mod you can close or delete here. Thanks - LZERI
I have the same problem with Cyclone V SoC kit.
Can you tell how you resolved this problem?
Best regards
