Losspost
7 years agoDE2-115/ RS-232 Broken Communication
Hi.
I am currently trying to communicate via pc to my FPGA Board. In the Simulation the Data Transmission works fine. But when I try to send Data to the real Board the Data doesnt make any sense at all. Even with the same data input to the board, i get different outputs from the FPGA Board. Anyone can help me?
My Code:
module UART(clk,uart_rxd,uart_txd,uart_cts,uart_rts,led_out);
input clk;
input uart_rxd;
output uart_txd;
//Clear to send
inout uart_cts;
//Request to send;
inout uart_rts;
output[7:0] led_out;
//8 times the Baud Freq.
localparam baud_counter_value = 5208/8;
//localparam baud_counter_value = 2500000;
reg[14:0] baud_counter;
//BaudClock
reg baud_clock_reg;
wire baud_clock;
//Inital CTS/RTS register
reg cts;
reg rts;
//Data Register
reg[7:0] data;
reg txd;
//LED Test Register
reg[7:0] led;
//Counter
reg[32:0] counter;
//Uart State Register
localparam
s_IDLE = 0,
s_DELAY = 1,
s_DELAY_RESET =2,
s_SEND = 3,
s_RECEIVE = 4,
s_TEST = 5,
s_RECEIVE_DELAY_RESET=6,
s_CLEAN_UP=7;
reg[4:0] state_uart;
//Baud Delay Counter
//Because baud_clock is baud_clock * 8. We have to wait 8 baud_clocks for 1 baud bid at 9600baud/s
reg baud_delay;
reg[4:0] baud_delay_counter;
reg delay;
initial begin
//Initialize Baud Clock
baud_clock_reg = 0;
baud_counter = 14'b0;
cts = 0;
rts = 0;
data = 8'b0;
led = 8'b00000001;
counter = 0;
baud_delay = 0;
baud_delay_counter = 4'b0;
//Inital state
state_uart = s_IDLE;
end
//Creating a Baud Clock Baudrate = 9600
always@(posedge clk) begin
if(baud_counter == baud_counter_value-1) begin
baud_clock_reg <= !baud_clock_reg;
baud_counter = 0;
end else begin
baud_counter <= baud_counter +1;
end
end
always@(posedge baud_clock && baud_delay == 1) begin
case(state_uart)
s_DELAY: begin
baud_delay_counter <= baud_delay_counter +1;
if(baud_delay_counter == 4) begin
baud_delay_counter <= 0;
end
end
s_RECEIVE: begin
if(baud_delay_counter == 8) begin
end
end
s_DELAY_RESET: baud_delay_counter <= 0;
s_RECEIVE_DELAY_RESET: baud_delay_counter <=0;
endcase
end
//Getting Request from PC to receive Data
case(state_uart)
s_IDLE: begin
//If Host Request to send Data
//Waiting for start bit
if(uart_rxd == 0) begin
state_uart <= s_DELAY;
end
end
s_DELAY: begin
//Wait for 4 Baud Ticks to "sample Data"
baud_delay <= 0;
state_uart <= s_DELAY_RESET;
end
//Activate Baud Counter
baud_delay <= 1;
end
s_DELAY_RESET: begin
if(baud_delay_counter == 0) begin
state_uart <= s_RECEIVE;
end
end
//Receive the Data
s_RECEIVE: begin
//Waiting for one "real" baud tick
baud_delay <= 1;
//Setting Least Significant Bit
data[0] = uart_rxd;
txd <= uart_rxd;
//Shift 0 bit one to the Left
//= because its only getting executed after the previous line was executed
//Dont Shift the Last Bit
if(counter != 7) begin
data = data << 1;
end
counter = counter + 1;
state_uart <= s_RECEIVE_DELAY_RESET;
end
if(counter == 8) begin
baud_delay <= 0;
state_uart <= s_TEST;
end
end
s_RECEIVE_DELAY_RESET: begin
if(baud_delay_counter == 0)begin
end
end
s_TEST: begin
led <= data;
state_uart <= s_CLEAN_UP;
end
s_CLEAN_UP: begin
data = 8'b0;
counter = 0;
txd <= 1;
state_uart <= s_IDLE;
end
endcase
end
//Update Baud Clock Signal
assign baud_clock = baud_clock_reg;
assign uart_cts = cts;
assign uart_rts = rts;
assign led_out = led;
assign uart_txd = txd;
endmodule1 Reply
- JohnT_Altera
I would recommend you to try the refence design from https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=163&No=502&PartNo=4 to confirm if there is any issue on the board or your design.
