14 years agoDE2-115 Ethernet throughput
I'm trying to send a video flow from my DE2-115 to a PC. To send 320*240 images with 16bit pixels with 25fps, I need a throughput of 320*240*16*25 = 30,720,000bit/s (below the 100Mbit/s offered by th...
14 years agoI believe your challenge is that the NIOS is a softcore with the same processing power as a CPU from 1997. http://www.tomshardware.com/reviews/mother-cpu-charts-2005,1175.html (http://www.tomshardware.com/reviews/mother-cpu-charts-2005,1175.html)
Add the TCP/IP stack, interrupt processing etc - it's just gonna be slow. For more speed you would need to interface with the ethernet chip or maybe the TSE core directly - handling framing and higher level protocols yourself. M.
