DE10-Nano mix GPIO I/O directions
- 4 years ago
Case closed! Many thanks!
I just noticed that this case has just been re-opened. Since your last post has been awhile ago may I know which specific problem are you facing?
Thank you.
Hello Bill,
Is there any update from you?
Thank you.
- BillM2564 years ago
Hi Amin,
I understand from Ashlesha that you've agreed to help, many thanks!
I never closed this case; I just didn't get an answer to my last post.
The open issue is mixing inputs and outputs on a single GPIO header of a DE10-Nano. Simple example: GPIO_1[1] = Input; GPIO_1[2] = Output; (and perhaps GPIO_1[3] = BiDir). My original post gives more detail including things I tried unsuccessfully.
Seems this should be easy, but I haven't figured it out, and, so far, no one has furnished the explanation.
Thanks again,
Bill
