de10-lite stuck
Quartus can successfully program the device (at least it shows 100% success), but nothing works.
All LEDR are On
CONF_DONE LED is Off.
Using:
Quartus 18.0
Windows 10
- Vicky1
May I know, which configuration (JTAG Configuration or Internal Configuration) are you doing?
Have you checked the board settings as per device handbook?
Please refer the FPGA Configuration Troubleshooter,
https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/devices/cfg-index/fpga-configuration-troubleshooter.html
especially link below,
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/ts-index/configuration.html#
Vicky
- CPinh4
Thank you for the support.
But I believe the board is damaged.
Back to work on Monday, it worked. Then, I thought it could be some problem with my computer.
Today, with same Computer, USB port and project, it stopped working again.
Thanks again.
- Vicky1
Have you gone through the my previous post? especially configuration issue link?
please refer : The Quartus II programmer reports successful configuration but the device/devices are not configured
please do visual check of board especially pins, rather clean it properly, monitor configuration signal voltage levels using standard oscilloscope & try to check implementation of simple D flip flop using JTAG Configuration on same board.
Vicky
