15 years agoDE0-nano system CD Control Panel "Error make sure quartus is installed"
hi, i recently buy a DE0 nano develpment kit, i install del quartus web edition 10.1 and i download de nios 2 10.1 from the download center of altera becouse it doesn't come with the free package dvd...
15 years agoError 82 is a failure to access the jtag server via its TCP port.
I would start by using jtagconfig to check that the basic connectivity is there - from a command window which has Quartus on its path type `jtagconfig --debug` and it should give you a full list of what's on each JTAG chain. Once this is working you know you have a correct Quartus install and can start trying from other tools.
