15 years agoDE0-nano system CD Control Panel "Error make sure quartus is installed"
hi, i recently buy a DE0 nano develpment kit, i install del quartus web edition 10.1 and i download de nios 2 10.1 from the download center of altera becouse it doesn't come with the free package dvd...
15 years agoI recently aquired a DE0-Nano board and I find the same problem ("error make sure quartus is installed") but I can't follow your suggestion. I can't download the .sof file since the PC does not recognize the on-board blaster. In the tools/programmer panel, I click in "Hardware Setup" and I get an error ("attempted to access jtag server -- internal error code 82 occurred").
Although I've installed the driver and, if I look in the Device Administrator the USB is detected as "Altera USB-Blaster", I can't make the Quartus II soft detect the board. This page (http://www.altera.com/support/kdb/solutions/rd04042011_1000.html) suggest a solution regarding a reset on the altera jtag server, but I don't find it where It should be. I use Quartus II 11.0 with control panel 1.0.2 on a windows 7 64 bits platform. Thank you.
