15 years agoDE0-Nano .pof programming
Hi I have a DE0 (Cyclone III) and a DE0-Nano (Cyclone IV). When active serial programming the DE0 with a .pof file I put the DE0 into PROGRAM MODE using the (RUN/PROG) switch. But I can't ...
15 years agoThanks you for the quick reply.
That solved the problem. I also referred to the following once you told me where to start (needing a .jic). http://www.altera.com/literature/an/an370.pdf
