15 years agoDE0-Nano NIOS II Question
I understand how to change an sof file to a jic, so that it can automatically run the code when the DE0-Nano gets turned on. My question is how do i make my program run automatically when after i...
15 years agoHi,
it is correct, that you can store both jic and elf into your epcs device. But make sure that your SOPC System contains the EPCS Serial Flash Controller IP. Select the EPCS Controller for the Reset Vector in your Nios II CPU and make sure that the Flash Offset for the SOF file is set to 0 Now you can flash your sof and elf file at the same time with the flash programmer in the Nios II Eclipse.
