ArleySalvador
3 years agoDDR4 IBIS Models
I am generating Startisx10 IBIS models for DDR4 pins and there are two pins which same function being assigned to different models:
| [Pin] signal_name model_name | A15 ddr4...
- 3 years ago
Hi Arley,
The IBIS model is correct. Only the name is not generate properly due to some bug from the Quartus.
You can use the model that has been generate from the Quartus.
Adzim
ArleySalvador
3 years agoHi Adzim,
Please, could you clarify what that means?
"The IBIS model that has been used is accurate."
Should I do anything to use to correct model for A15 (for instance)?
A15 ddr4_dq(15)~pad pod12_rtio_g48c_r48cp1_dqs_lv
Arley
- ArleySalvador3 years ago
Hi Adzim,
Please, could you clarify your last help?
Should I use the model as provided by Quartus tool even though it is not correctly assigned to DQ model?
Look foward for you reply.
Arley
