ArleySalvador
3 years agoDDR4 IBIS Models
I am generating Startisx10 IBIS models for DDR4 pins and there are two pins which same function being assigned to different models:
| [Pin] signal_name model_name | A15 ddr4...
- 3 years ago
Hi Arley,
The IBIS model is correct. Only the name is not generate properly due to some bug from the Quartus.
You can use the model that has been generate from the Quartus.
Adzim
AdzimZM_Altera
3 years agoHi Arley,
I have checked this issue internally and I found one similar issue.
There is a bug with Quartus IBIS generation. The Quartus does not generate the correct IBIS model name for EMIF I/O pins.
The IBIS model that has been used is accurate.
Adzim
