11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years ago --- Quote Start --- Right, I understood the error more clearly. OK for the ports names that are not the same but where? I've seen the HDL example but I don't know what file I have to change. --- Quote End --- This is why errors are good. You're forced to read the code and understand :) Given that you're trying to run qsys_system_bfm_master_tb, wouldn't you think that would be the place to start looking? In the posts above this one, you state the path to that file, i.e., $TUTORIAL/hdl/qsys_system/test/qsys_system_bfm_master_tb.sv If you look at that file, you should see the qsys_system instantiated. If the port names have changed in the generated qsys_instance (as shown by "Generate HDL Example"), then change the instance port names to match (you can leave the design-level signal names that connect to the ports the same) and the design should work. Cheers, Dave
