11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years agoI'm doing your altera_jtag_to_avalon_mm_tutorial but I got errors.
When doing 4.5.2 I first have multiple warnings when running "com":** Warning: ./..//submodules/altera_merlin_traffic_limiter.sv(512): (vlog-2583) - Some checking for conflicts with always_comb and always_latch variables not yet supported. Run vopt to provide additional design-level checks. Then I get errors when running "vlog -sv $TUTORIAL/hdl/qsys_system/test/qsys_system_bfm_master_tb.sv -L qsys_system_bfm_master": ** Error: C:/Users/rm231795/Documents/work/JTAG/cellule/quartus/jtag_to_avalon_mm_tutorial/hdl/qsys_system/test/qsys_system_bfm_master_tb.sv(48): Could not find the package (verbosity_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line. And when trying 4.5.3 I get # vsim +nowarnTFMPC -L work -L work_lib -L altera_common_sv_packages -L rsp_xbar_mux -L rsp_xbar_demux -L cmd_xbar_mux -L cmd_xbar_demux -L limiter -L id_router -L addr_router -L led_pio_s1_translator_avalon_universal_slave_0_agent -L bfm_master_m0_translator_avalon_universal_master_0_agent -L led_pio_s1_translator -L bfm_master_m0_translator -L p2b_adapter -L b2p_adapter -L transacto -L p2b -L b2p -L fifo -L timing_adt -L jtag_phy_embedded_in_jtag_master -L rst_controller -L mm_interconnect_0 -L onchip_ram -L button_pio -L led_pio -L jtag_master -L bfm_master -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cycloneive_ver -t ps qsys_system_jtag_master_tb # ** Error: Failure to obtain a Verilog simulation license. Unable to checkout any of these license features: alteramtivsim or alteramtivlog.# Error loading design
when trying "elab +nowarnTFMPC" I see license problems. I think it's because I'm using only VHDL and not VERILOG at work so I changed Qsys choices to generate VHDL but I have other errors. What can I do? ------------ add ------------------- I thought of a license problem so I used the ASE version (no license required) but it's the same: first warnings, then errors...
