11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years ago --- Quote Start --- But the signals are changing depending on ext_clk that is about 100 times slower than the original clock and these signals are resynchronized by a fifo between the Quartus design and the Qsys system. It's not enough to say they are static? --- Quote End --- If you are reading the data via the USB JTAG interface then, the read interface is the limiting factor. So your signals are dynamic, and need to be captured into RAM, and then that RAM can be read out over USB. --- Quote Start --- And a "no matter" question: what is (is there) the command I have to use in Quartus to list the content of the working directory? I tried 'ls' and 'dir' but it won't work. --- Quote End --- The Quartus console is a Tcl console, you can use Tcl commands. Cheers, Dave
