11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years ago --- Quote Start --- For me "simulation" means a logical way of predicting what would happen, with Modelsim or Questa for example. SignalTap II is more a tool to analyse what really happens after downloading the design in the FPGA. --- Quote End --- In general, you have to use both. For example, lets say I have a board with a microcontroller on it, and the firmware in that microcontroller implements a parallel interface to the FPGA, and I do not have access to that firmware (eg., I have this situation on a Digilent Xilinx board). Using SignalTap II (or in reality Xilinx Chipscope), I can measure the timing of that interface, and then use that timing in the bus functional model (BFM) simulation of the parallel interface. Once I have a realistic BFM, I can simulate the design until I am confident it works, and then hardware test. Working this way, I generally have no issues once I get to hardware tests. Cheers, Dave
