CycloneV U-Boot FPGA Load Fails: Code -6
Hello, I am trying to program the FPGA of my CycloneV from U-Boot. It appears to be failing and I am not sure why. The exact u-boot commands are
echo --- Programming FPGA ---
echo -----Loading image------
# load rbf from FAT partition into memory
fatload mmc 0:1 ${fpgadata} socfpga.rbf;
# program FPGA
echo -----Print filesize-----
printenv filesize;
echo -----Program FPGA-------
fpga load 0 ${fpgadata} ${filesize};
# enable HPS-to-FPGA, FPGA-to-HPS, LWHPS-to-FPGA bridges
echo -----Enabling IFs--------
bridge enable;What I am seeing during boot is the following
Hit any key to stop autoboot: 0
449 bytes read in 3 ms (145.5 KiB/s)
## Executing script at 02000000
7007204 bytes read in 366 ms (18.3 MiB/s)
filesize=6aebe4
Command 'load' failed: Error -6
switch to partitions #0, OK
mmc0 is current deviceWhat does the error code -6 mean? When I look at FPGA manager status in Linux, it prints the following.
root@cyclone5:~# cat /sys/class/fpga_manager/fpga0/state
write init5 Replies
- Ahmed_H_Intel1
Is this based on the GHRD? or custom design.
- JFrye2
@AhmedH_Intel , sorry for the delayed response. This is a custom design. I tried putting my question out on the u-boot mailing list and they redirected me back here since Intel maintains https://github.com/altera-opensource/u-boot-socfpga
I am targetting DE1-SoC with the u-boot software from the repo above.
I tried socfpga_cyclone5_defconfig and that led to the programming error.
I also tried socfpga_de1_soc_defconfig and I didnt even get console messages when I booted when I used that configuration.
I can send you a zip of the hardware design if needed.
- Ahmed_H_Intel1
Are you trying to store the kernel or the FPGA image on the flash? (like Nand flash)
I saw this issue before while storing them on a NAND flash. We recommend storing the file system on NAND.
Please confirm.
- sf69
with the Cyclone V SOC Development Board
i have the same issue, loading from u-boot the rbf file:
=> dhcp ${loadaddr} soc_system.rbf
Bytes transferred = 7007204 (6aebe4 hex)
=> fpga load 0 ${loadaddr} $filesize;
Command 'load' failed: Error -6But if i compress the rbf file:
=> dhcp ${loadaddr} soc_system_compressed.rbf
Bytes transferred = 3051080 (2e8e48 hex)
=> fpga load 0 ${loadaddr} $filesize;it works
is there a size limit somewhere ?
thanks
- MV
I think this is a good question and begs for an answer.
Running into a similar issue and also speculating about a size limit of .rbf file that perhaps u-boot or the FPGA driver is able to handle.
Anyone can shed light on this?
Thanks!
