14 years agoCyclone3 with HSMC data conversion board
Hi, I just bought the DSP development kit - Cyclone3 edition (3C120). It comes with an ADC/DAC conversion card that can sample the ADC at 150 MSpS. However the documentation is giving me some prob...
14 years agomosgaard,
I've had the same issue with this dev board (actually why i signed up for the forums) There are pin descrepencies between the HSMC reference document PDF and the Dev Board reference document. the DevBoard reference PDF seems to be the correct one so far. Also, if you installed the reference designs, there is one called "cycloneiii_3c120_dev_golden_top" in the examples folder which you can import the pin assigments. This contains all the HSMC pins and are correct (I hope) . Also, if you haven't already, make sure you define the IO standard for your clock pin as LVDS and define your clock_bar signal as such: (clk_25_out is my pll output. this is copied straight from pin assignments) ok clk_25_out i/o standard lvds yes ok clk_25_out location pin_g6 yes ok clk_25_out(n) location pin_g5 yes You can get the latest reference examples/documentation here: http://www.altera.com/products/devkits/altera/kit-cyc3-dsp.html#documentation
