RK3
7 years agocyclone V device 5CSXC6C6U23C8NES is supported in which Quartus software version?
AnandRaj_S_Intel
7 years agoHi,
Thanks for sharing information,
Can you just open command prompt/terminal and type quartus_pgm --auto or jtagconfig.
And check if you can see any of below messages.
- Error (213013): Programming hardware cable not detected May be due to download cable problem, TDO is not connected properly, a noisy TCK signal, or TDI shorted to GND, pull-up and pull-down resistors connected to the JTAG. USB Blaster problem replace USB cable /Blaster kit or installation issue reinstall Quartus which will install the drivers.
- USB-Blaster II [USB-1] Unable to read device chain - JTAG chain broken
Monitor the signals like nStatus Conf_Done and others.
Check with GUI instead of command prompt or terminal for simplicity.
Anand Raj Shankar
