14 years agoCyclone IV
Hi, I need help because for my final thesis I wanna do a smart antenna so, anybody know if it's possible connect 2 antennas to this device?? http://www.altera.com/products/devkits/altera/kit-cyclo...
14 years agoThat's not the board I would recommend. Although it could be done, it doesn't have the connections you'll require.
I would look for a board either with the HSMC connectors on it or that already has ADC/DAC on it that can sample your signal at the rate you require. With this board, you really only have the GX Transceivers and PCIE ports, so you would have to have your data connected through one of those.. Pete What Frequency band are you hoping to work at? Pete
