cyclone 10gx-lvds_cdr
Hi
Can you share with us a sample design that is causing the issue?
Eng Wei
- smile1235 years ago
您好,不好意思,现在才看到您的回复,下面这个是我用20.1_pro的软件建立的工程,非常期待您的解答。
- EngWei_O_Intel5 years ago
I am sorry for overlook your response here. Let me take a look and get back to you.
Eng Wei
Hi there
We looked at the design and the issue seems to be from the generated SDC file of the LVDS SERDES IP. We created a standalone LVDS SERDES design with the same setting as your design does, and we don't see such error exist.
Few things we want to point out:
1. there are unconstraint clocks in the design, though those unconstraint clocks don't seem related to this issue after we fixed them.
2. we switched the LVDS SERDES IP from soft-CDR to RX DPA mode, and we see that this error goes away.
3. We created a simple design with just the LVDS SERDES IP with all the similar setting, and we don't see this error happened. We compare the generated SDC file with the one in your design, and both SDC files are the same.
Questions:
1. Do you upgrade the IP which is generated from other Quartus version? From the Quartus setting file, we saw that the original Quartus version was 17.1.
thanks
Eng Wei
