Cyclone 10 LP Evaluation kit not booting NIOS from EPCQ flash
Thank you for the information in the post from above. I am having issues running the boot copier directly from EPCQ64 using the Cyclone 10LP FPGA Kit .
Following this post and attached zip folder C10LP_NIOS2.zip I have completed the following steps:
STEP 1: SET PARAMETERS WITHIN PLATFORM DESIGNER
1) Using Nios II/e
RESET VECTOR PARAMETERS:
- Reset Vector Memory : PERIPHERALS_EPCQ64.avl_mem
- Reset Vector offset : 0x 0008 0000 (.SOF Image size - 0x0003 B162)
- Reset Vector : 0x 0088 0000
EXCEPTION VECTOR PARAMETERS:
- Exception Vector Memory: PERIPHERALS_OCRAM.s1
- Exception Vector offset: 0x 0000 0020
- Exception Vector : 0x 0101 0020
2) Within the PERIPHERALS QSYS FILE:
OCRAM (On Chip RAM)
- s1 Data width : 32
- Total Memory Size : 40,500 bytes
- Initialize Memory Content - (Check marked - ENABLED - also tried with this option disabled)
Serial Flash Controller II Intel FPGA IP
- EPCQ64
STEP 2: Quartus Prime compile (re-attach SYSTEM.qip)
STEP 3: Start Eclipse IDE (setup project, import files from zip folder)
STEP 4: Start the BSP Editor
- Main Tab: hal.linker (ALL UNCHECKED)
- allow code at reset
- enable alt load
- enable alt load copy rodata
- enable alt load copy rwdata
- enable alt load copy exceptions
- Linker Script Tab
- Set all to OCRAM (.bss, .exceptions, .heap, .rodata, .rwdata, .stack, .text)
- .entry : only linker section set to EPCQ64_AVL_MEM
- CLICK GENERATE
STEP 5: Build Project ( successful compile)
STEP 6: Click Programmer, download .sof only (LED's now are illuminated on the board)
STEP 7: Run the Debug from Eclipse IDE
- LEDs are now toggling live
- NIOS II Console now showing hello world strings
- Successfully running
STEP 8: If reset pressed, SOF file erased, confirmed
STEP 9: Generate .HEX Files
- Make Target -> Build -> mem_init_generate -> Click Build (Generates the below)
- PERIPHERALS_EPCQ64.hex
- SYSTEM_PERIPHERALS_OCRAM.hex
STEP 10: Load .JIC using the Application Note (AN-736)
- TEST JIC with only .SOF and Flash loader
- Flash loader : 10CL025Y
- SOF Data Properties
- Page 0
- Select Start
- Start Address : 0x0
- SOF File Properties
- Compression checked (ENABLED)
STEP 11: Click Programmer, download .jic
STEP 12: Click on reset button on board - (LED's now are illuminated on the Cyclone 10LP Kit)
STEP 13: Run Program on Eclipse, Power Cycle, run program on Eclipse again to verify SOF is loaded properly
- program ran with no issues
Up to this point, the steps are clear. The next steps is where i see the issue where the code is not running upon reset. ----------------------------------------------------------------------------------------------------------------------------------------------------
For the next steps, I am executing the following steps:
STEP 14: Add hex file to JIC, under the Convert Programming Files tab
- Absolute Addressing
- Big Endian Selected
- Select file: mem_init -> PERIPHERALS_EPCQ64.hex (size 9.06KiB)
- Click Generate
- output file generated successfully
- SOF File and Flash Loader, loaded from previous step
STEP 15: Click Programmer, download new .jic (LED's now are illuminated on the Cyclone 10LP Kit)
STEP 16: Click on reset button on board - (LED's now are illuminated on the Cyclone 10LP Kit)
Note that if the code was running we should see the LEDs toggling as it is when i run the project.
LEDs are not toggling. So when I recompile, and run the debug it is now working again.
Questions:
1) From the steps above, I would assume that my .SOF and .ELF are properly being generated and running, What is unclear is why is my program not automatically loading after reset.
2) Am I missing any options within the BSP editor?
3) Is there anything missing from Platform Designer?
Thank you for your time and help in advance.
My apologies, the code is working now. I uncommented the printf("hello world") statement and that causes the LEDs to not toggle fully. Commenting it out fixed the issue.
