mehta_expai
4 years agocyclone 10 gx fpga
I had downloaded Quartus prime pro and the device installation file for cyclone 10 gx.
When i have installed Quartus prime pro & started new project ,but when the board selection window i...
- 4 years ago
If you are saying that you have a development kit and you're not seeing the board in the New Project Wizard, I've found that few of them end up appearing there. You may have to select the device on the board and manually create I/O and other assignments. Or you can look for a project template (.par) that might be available for your board.
sstrell
4 years agoIf you are saying that you have a development kit and you're not seeing the board in the New Project Wizard, I've found that few of them end up appearing there. You may have to select the device on the board and manually create I/O and other assignments. Or you can look for a project template (.par) that might be available for your board.
