DWolf9
6 years agoCyclone 10 GX development kit USB 2.0 PHY/Microcontroller function?
I am trying to understand what function the USB 2.0 PHY (CY7C68013A-56LTXC) on the Cyclone 10 GX development board is providing. More specifically since this device also contains a programmable microcontroller I am looking for any information on what this is programmed to do on the development board or source code if it is available.
Thank you
1 Reply
- AR_A_Intel
Hello
Welcome to INTEL forum. The USB 2.0 PHY (CY7C68013A-56LTXC) on the Cyclone 10 GX development board is use to connect pc to dev kit via on-board USB port or an external USB-Blaster II header and this device is used for PFL configuration mode. For more refer to 4.4. FPGA Configuration
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-c10-gx-fpga-devl-kit.pdf
