GMagy
7 years agoCyclone 10 GX Development Kit malfunction
Hi, I've been working with the Cyclone 10 GX Development Kit without problems for weeks developing an IP stack solution using Ethernet. Recently the board's behaviour changed so that the link is nev...
GMagy
7 years agoHi,
Yes, it was working for a while, then it stopped working.
I did not do any hardware modification on the board.
All I did was
- downloading software from the NIOS II Sw Build Tools for Eclipse
- downloading default configurations (.sof) via the Board Test System
- downloading .sof from the Quartus Prime Programmer
After it's behaviour had changed I also tried to program the serial flash (EPCQL1024) from the Quartus Prime Programmer.
So I am 100% sure I did not do anything illegal.
Yes, I can program .sof files, but, as I had described, something seems to be wrong with that, as
- using the Simple Socket Server example the Ethernet is not working
- The serial flash can be programmed neither from BTS (Factory Restore) nor from the Programmer.
Gabor
