BillM256
5 years agoCreate custom logic elements with classic logic symbols for Quartus Block/Schematic Editor
I’m working on a design using the Quartus Block/Schematic Editor that requires classic TTL-like logic symbols, e.g., and, or, inverter, f/f. It would be useful if I could build my own primit...
Nurina
5 years agoHi,
To answer your questions:
- Not exactly, I would say it does and you can see them in the block design file created from the Verilog/VHDL code. But when you insert this symbol in a block design file it will appear as a block.
- I assume you want them to appear as logic symbols in you block design files. I don't think there's a way to do that. You can double-click on them and it will lead you to open the generated bdf file or the Verilog/VHDLfile.
- As far as I know, AHDL will not help. It would be the same as above.
- There is no better way to do what you want to do unfortunately. Just give your symbols and their ports a meaningful name so that it'd be easy for you to remember and visualise.
Nurina
BillM256
5 years agoHi Nurina,
You confirm what I suspected is the case. I'm hoping someone has a solution, so will keep the issue open, but I'm not optimistic.
Thanks for taking time to help!
Bill
