matif
7 years agoCorrect Output of Transceiver onto UART Terminal
Hi all, I made a setup where I connected counter (0 to 14) and a constant (8'hBC) to a mux. The mux based upon rx_syncstatus output sends either counter or constant data to a transceiver operating a...
matif
7 years agoHi Chee Pin,
Thank you so much for your reply.
- Yes case 04274941 and 04274469 are the same cases. Actually I wasn't getting a responce thats why I filed another similar case with more details.
- Yes, I have issues with RX Parallel Data output display at Uart output terminal. I want to see the consistent counter sequence like 0,1,2,3,4, upto 14 but as you can see in my post I am getting inconsistant data. Some of the people suggested me that because I am running Linux on my cyclone V board that is why my application reading rate is really slow but I also tried to run the counter at really slow speed like at just 10 Hz but even then I was not getting the consistent data. To be sure that the transceiver is synchronized, I connected the rx_syncstatus output to one of the LED on board and the LED is lighted up means transceiver is synchronized.
- Yes, for sure, I can share with you my quartus project file so that you can have a look. Where should I share it because I am not able to upload the file here at website remember last time we also tried to upload the transciever loopback example and it didn't work so you had to email me the file. So just let me know how can I share my transciever file with you.
And thank you so much for your reply. You always help me. Appreciated.
