JShan27
6 years agoconfigure quartus PL to start model sim within it- Manjaro Linux (Arch packages)
I can not get modelsim starter ed to start within quartus prime light 19.1. I specifically installed it with its own installer file. I get a license error when I attempt to run a simulation in tab:...
AR_A_Intel
6 years agoBut before setting up modelsim, would you kindly help check whether your machine is supported or not (OS) by referring to ling below:
https://www.altera.com/support/support-resources/download/os-support.html
- JShan276 years ago
My operating system is Manjaro Linux, which is based off of Arch Linux ( Manjaro will use the same Arch files repositories?),,,, so no ModelSim is not supported by Manjaro Linux in accordance with the link you showed. I guess I am trying to manipulate the files (vco) in order for Manjaro to be able to run modelsim since that is what it seems like others have been doing,, albeit with alot of research and manipulation... hence showing you the link to a web page showing efforts to make it happen. Thanks
